SALES ORDER LINES
UK: +44 (0)1761 417714
USA: 281 717 1145
Home
Home
About Us
Media
Technical
Contact
Products
Snap Fit & Ear Clamps
Ezyclik™-P
Ezyclik™-M
Zero Leak Ear
Compensating Clamps
Ezyclik™-M+
Double Wire Spring
Worm Drive & Screw Clamps
Worm Drive BS5315
Worm Drive DIN3017 – 9mm
Worm Drive DIN3017 – 12mm
Worm Drive SAE J1670
Quick Release Worm Drive
Mini Screw
Double Wire Screw
Plastic Worm Drive
Continuous Worm Drive Kit
Heavy Duty Clamps
Bolt & Barrel
T-Bolt
Worm Drive Super Torque
Preformed
Cable Retention
Nylon Cable Tie – Standard
Nylon Cable Tie – Flat Head
Plastic P Clips
Banding & Strapping
Metal Banding
Installation Tooling
Manual Tools – Cable Ties
Pneumatic Tools – On Request
Home
>> Mini Screw
Mini Screw
Available UK Only
UK
UK
Mini Screw Hose clamps or Petrol Pipe Clips are particularly suitable for soft hoses and small diameters. The clamp forms a complete circle and has smooth edges.
‹‹ PREVIOUS
NEXT ››
PAGE
4.6
Your Javascript is turned off
