SALES ORDER LINES
UK: +44 (0)1761 417714
USA: 281 717 1145
Home
Home
About Us
Media
Technical
Contact
Products
Snap Fit & Ear Clamps
Ezyclik™-P
Ezyclik™-M
Zero Leak Ear
Compensating Clamps
Ezyclik™-M+
Double Wire Spring
Worm Drive & Screw Clamps
Worm Drive BS5315
Worm Drive DIN3017 – 9mm
Worm Drive DIN3017 – 12mm
Worm Drive SAE J1670
Quick Release Worm Drive
Mini Screw
Double Wire Screw
Plastic Worm Drive
Continuous Worm Drive Kit
Heavy Duty Clamps
Bolt & Barrel
T-Bolt
Worm Drive Super Torque
Preformed
Cable Retention
Nylon Cable Tie – Standard
Nylon Cable Tie – Flat Head
Plastic P Clips
Banding & Strapping
Metal Banding
Installation Tooling
Manual Tools – Cable Ties
Pneumatic Tools – On Request
Home
Available USA Only
USA
USA
HCL’s robust perforated Worm Drive clamps are manufactured in accordance with SAE J1670. They are designed for higher sealing pressure with minimal torque.
‹‹ PREVIOUS
NEXT ››
PAGE
4.4
Your Javascript is turned off
